how do i re-activate my plan after i've accidentally unsubscribed?
How do i re-activate my plan after ive unsubscribed?
it's when clicking on the notification, the page it brings me to does not exist,
there is no option to reactivate.
  • K L.
    K L. Posts: 210 ✭✭
    If you dont have the option
    you need to msg fizz (by fb messenger its a good issue for me)
  • Olivier R. #3666
    yes just to reactivate your plan
  • Jimmy N. #14505
    Jimmy N. #14505 Posts: 620 ✭✭
    Shouldn't be too hard normally.
    sman Posts: 4,315 ✭✭
    Tatyana, did you found the button?
  • André L. #16536
    André L. #16536 Posts: 647 ✭✭
    Thanks Mike for the clear response.  Should be the accepted response IMHO
  • poker85
    poker85 Posts: 1,052 ✭✭
    Yes is possible :)
  • Chris K. #7521
    Chris K. #7521 Posts: 486 ✭✭
    If you don't see reactivate then try contacting support
  • Jimmy N. #14505
    The best solution is to speak with them
  • GBy_6B8OA
    GBy_6B8OA Posts: 503 ✭✭
    it's possible
    You can do it !!
  • vanigh
    vanigh Posts: 328 ✭✭
    Welcome back to Fizz in advance. :)
    Whizz Posts: 19,148 admin
    Hi Tatyana ,
    I see on your account that your Home Internet plan has been cancelled. You'll have to log-in to your Fizz account and go My plans - under your deactivated Home Internet plan you'll see a green "Reactivate" button. Click on it and follow the steps to reactivate your plan again. You may have to schedule a new appointment and have another technician to arrive at your house to check the connection. Please check this faq link to guide you further: https://fizz.ca/en/faq/how-do-i-manage-appointment-technician-visit-my-service-address. You can also reach us via live chat or facebook messenger and we'll help you further:
    https://fizz.ca/en/contact-us / https://facebook.com/fizzca.
    Have a good one!
    Radu
