HI everyone,
I'd like to get the plan in the attached image. 95% of my calls will be international call to Italy (but less than 500mins). For local calls, I would use the wallet for pay-per-call fees.
I wondering if the 500mins will also incur pay-per-call fees if I don't have unlimited minutes?
This is what it shows when you choose this option :
International Calls
For $5 per month, get a fixed number of minutes to make calls to one of the countries on our special rate list.
There is no mention about required unlimited minutes or extra charge so you should not be charged if you don't have unlimited minutes
I believe that you must contact the support
I never read such question
That's a very good question. I would love you to come back to us with the answer please :)
I guess it s not included cuz otherwise the plan would just be an international plan.
DeniG,
You are only Fizz users like you.
To get a good recommandation:
Please, contact the Fizz support by chat online (from 8h00 to 21h00).
To do this without problem;
First, connect you to your Fizz account.
Then, open a second window and type:
Wait a few seconds until you see the green chat bubble down to the right of the page.
When you see it, click on it.
Your chat session with Fizz begins.
Hi DeniG, You bring a good question, which we do not have as answer to. As MichelP pointed out, this forum is supported by Fizz customers (you and I) helping each other when we can.
When you do get an answer, please come back to this post to share it with us!
I think you will have to pay for every minute.
If you only makes long distance calls, why not use a VOIP, It will cost must less. Skype, Google, etc...
Great idea Chris
it s okay. if you can select it... it s fine.
you can also chat with FIZZ with the contact form or fb message.
@DeniG
If you contact the support and you get an answer can you please let us know
in the meantime, if you need a referral code this is mine NPONZ (iall letters).
Did you got an answer? Or will you just try it to test for the first month?
Let's us know. :)
i dont think so
