I'm in a meeting. My call dropped 5 times so far (3 beeps, hangs out). What is going on?
Kim F. #3317
Kim F. #3317 Posts: 5 ✭✭
I'm sitting at my desk (not moving). Full bars signal.
  • I'd suggest trying to reach out customer service chat if you want them to have a look at it. From our side, it's hard to tell if you have some signal issue, a cellphone issue or some network issues like Mike suggested.
    CHAT
    • Go to this page https://fizz.ca/en/solutions
       if you are not connect login
  • André L. #16536
    André L. #16536 Posts: 647 ✭✭
    According to Fizz' status page: https://fizz.ca/fr/faq/etat-services There are no major outages.
    Personally, I'm not sure they would list all of their trouble tickets here...
    Dropped calls can occur for various reason, from the cell towers, to the call swapping, to transfer to/from LTE/HPSA/etc to the actual mobile phone too busy.
    If you can identify when the dropped calls occur (always at the office, or every time you're in your car crossing the bridge, etc.) then you can contact Fizz support to get them to investigate further.
