Can both English and French Community Hub questions be viewed together?
hc0468
Posts: 168 ✭✭
It would be nice to see all Community Hub questions regardless of language. Is that possible? And if not, can this be a feature request?
20
You can only see in the LeaderBoard & Activity, but only the last 5 activity, otherwise you need to my account and all activity but it is a pain in ......
It will be create a rss feed6 -
It's not possible.
See the leaderboard, and activity, on the english side or in french is the same last 5 activities.
You have to switch from both sides of the community hub.7 -
Thanks for the answers. It's too bad.. Any chance of getting an option to view all together?5
Hc0468
It would be nice indeed. The only thing I can tell you is from my experience.
One little change was made after I made it a suggestion. The Whizz told me to put my suggestions in the caregory: mobility/idea.
He said that's where they look for our suggestions.8 -
I don"t think it will hapoen anytime soon4
I don’t think it’s possible...4
nope, not possible. But you can simply toggle between the two by pressing the language button on the top right.5
So it doesn't seem possible right now.
Thanks Isabelle for the suggestion. I created a feature request under the Mobile/Idea category. It is currently under moderation, as is common with many of my posts, so it's not visible at the moment. (What could be controversial about that!)
UPDATE: Feature request is live now: https://community.fizz.ca/questions/2208120-feature-request-option-view-english-french-community-hub-questions-together5
