does fizz allow us to make calls anonymously? i can't
LlF
LlF Posts: 4 ✭✭
hi, first of course is whether this function is enabled on fizz network?
if yes what is the command to hide my ID on a per call bases? (there seems to be a few out there, which one to use on Fizz?)
what might be the cause if i can not hide my number on a just reset iphone?
thanks
    Mike Posts: 20,638 ✭✭
    Try adding *67 before the number
  • Olga P. #15146
    Olga P. #15146 Posts: 719 ✭✭
    Hello Lif
    I suppose you need to search that in your phone settinegs or add *67 before making a call.
  • LlF
    LlF Posts: 4 ✭✭
    @Mike:
    i can not even make the call with *671514....
    it says le forfait actuel ne vous permet pas deffectuer cet appel...
  • The command is
    #31# followed by the number you want to contact.
  • Thanh S.
    Thanh S. Posts: 360 ✭✭
    If i remember correctly, I don't think Fizz includes that service, when we signed up. Because normally, every company writes down that it's included.
    Otherwise, try to change your phone setting, it might work. What phone do you have ?
    @Louis-Phillipe Thank you
    MichelP Posts: 8,733 ✭✭
    Put *67 before you make your call.
    @MichelP please read the previous messages before reply
  • Nini G. #13860
    Thank you Louis-Philippe, I did not know this trick!
  • Chris K. #7521
    Chris K. #7521 Posts: 486 ✭✭
    I don't have Fizz for my mobile, but it is a setting on my phone so I assume that it should be possible. There is an option to send caller ID, I simply unclick it.
  • Abdul R. #3217
    Abdul R. #3217 Posts: 46 ✭✭
    Okay so I just tried it and when I use *67 before the number I want to call, I am not able to make the call. However, when I use #31# before the number I want to call, the call goes through and my number is hidden.
  • Alejandra D.
    Alejandra D. Posts: 272 ✭✭
    Can't you try just by setting the phone ?
  • Thanh S.
    LIF, which solution worked for you ? Please let us know.
  • Olivier R. #3666
    if you are using android you can make private call in the phone settings
  • Jimmy N. #14505
    Jimmy N. #14505 Posts: 620 ✭✭
    Normally, it should be pretty easy to set that up.
