Why are you changing me 2 times per months ?!
I just checked my RBC transactions history, and I discovered that you charging me twice each month! ************ and ********* ! Fix this !
Unbelievable. Contact me as soon as possible!!!!!!!!!!!! Otherwise I will cancel my two plans and home internet !
  • Olivier R. #3666
    please be in touch with the support.
    Fizzy Posts: 10,897 ✭✭
    Is it possible you have another plan or account using the same card?
    In any case, Fizz support can straighten it out for you.
    https://fizz.ca/en/contact-us
