international roaming to Asia countries
Sherry W.
Sherry W. Posts: 2 ✭✭
I will travel to Asia countries tomorrow and stay at Singapore for 4 months. Does Fizz has international roaming service in Singapore, as well as China and Japan? if yes, please advise how to buy the plan. It is much appreciated that you can reply as soon as possible. Thanks
  • Sherry W.
    Thanks a lot Mike for timely response and good information / suggestion!
  • Olga P. #15146
    Olga P. #15146 Posts: 719 ✭✭
    Hello Sherry, like Mike already told you, you can only buy add-ons.
    Mike Posts: 20,723 ✭✭
    Hi Sherry, if you consider the question answered can you close the post picking the best answer
    We are users and the best answer is our reward, you can pick only one
  • Nini G. #13860
    Mike has the best answer, choose it to close the discussion.
    MichelP Posts: 8,733 ✭✭
    Sherry,
    You can add add-on with data and sms only.
    Use the application Fongo for your calls or Whatsapp or Messenger.
    It can represent a cheaper solution the buy a local sim card in theses areas.
    Have a wonderful and amazing trip in Asia!
    You can add only add-ons (block of data).
    sman Posts: 4,300 ✭✭
    Yes mike has the best answer, can you choose it to close the discussion.
  • Aaron T. #7761
    Aaron T. #7761 Posts: 62 ✭✭
    As usual Mike Got it ... He's supa fly
    Sorry I couldn't resist as several people have acknowledge Mike has the best answer.
    Thanks Mike for your wealth of knowlegde
  • Jimmy N. #14505
    Jimmy N. #14505 Posts: 620 ✭✭
    For 4 montjs, it's better with local providers.
  • Berts
    Berts Posts: 824 ✭✭
    Follow Jimmy answer....
    @Sherry I believe that you got your answer, can you please close the discussion clicking on "Make this a best answer."
  • Nini G. #13860
    Please choose the best answer to close the discussion.
