Calculating travel add-on?
Is it possible to track my usage of the 1g travel add-on I bought? I only see my overall data tracking.
Thanks!
  • Samtou
    Samtou Posts: 39 ✭✭
    Hi Marie-Eve
    I have never bought travel add-on and didn't find most pertinent information on the subject, but generally, to see your usage of an add-on, you click on "see usage" in the "overview" or "my plans" and then "daily usage". If it doesn't work with travel add-on, contact Fizz by the green bubble that appears when you are in their FAQ. Let me know!
  • Nini G. #13860
    Communicate with Fizz by messenger, that’s what works best for me ! Hopefully you will get the answer. Happy New Year!
  • Jimmy N. #14505
    Jimmy N. #14505 Posts: 620 ✭✭
    Keep track of your "Mobile" data usage in your phone. you can also keep Fizz page as a bookmark to have access to it rapidly. It is pretty accurate in updating live.
  • Berts
    Berts Posts: 824 ✭✭
    Call Fizz for answer by messenger or chat.Happy New Year!
    MichelP Posts: 8,733 ✭✭
    Marie-Eve,
    The only solution for you is to reset your phone data counter.
    A this moment, you have an idea how data has been used approximately.
    Fizzy Posts: 10,923 ✭✭
    You should see it on your account under [My Plans]
  • Olga P. #15146
    Olga P. #15146 Posts: 719 ✭✭
    Thank you Fizzy!
    sman Posts: 4,319 ✭✭
    Fizzy gives us a good example
    Thank you for sharing
    But why Marie-Eve cannot see it
  • Marie-Eve O. #13134
    Thanks Fizzy! I was looking in My Usage.
