Data going down ?
Adèle C.
Adèle C. Posts: 6 ✭✭
Why is my data going down even on my wifi at home? You know why?
  • Smilemars
    Smilemars Posts: 156 ✭✭
    I suggest to turn off your data when you use your wifi at home. By doing that, you are certain that your data usage won't go down.
  • Jimmy N. #14505
    Jimmy N. #14505 Posts: 620 ✭✭
    Go to your network usage settings and find out which apo is using mobile data in the background. Deactivate it.
  • Felix D. #15236
    Felix D. #15236 Posts: 88 ✭✭
    On Android enable the data saver as described here:
    https://support.google.com/pixelphone/answer/7055392?hl=en
  • Olga P. #15146
    Olga P. #15146 Posts: 719 ✭✭
    That's because of the background application.
    MichelP Posts: 8,733 ✭✭
    Adele,
    I am enough confident that you lost your data by the background of all your applications.
    Also, maybe one good suggestion:
    turn off your data on your phone while you're at home using the wi-fi.
  • Jimmy N. #14505
    My gf is being at home for the last 3 months (baby), yet instagram is using a lot of her data even if we deactivated it to use background data, we are figuring it out still
  • Nini G. #13860
    It might some apps that are taking dates without you using them.
