Gift data to mybfriend, the system to the data away from my account, but my friend did no receive it
Usually this is worjing very well, contact the support.
Only them can check
Allan,
Did you give your data by choosing her phone number?
I think, it's work better with the phone number than by your email.'s friend.
Chat with Fizz team to resolve this:
@ Allan: does your friend have data in his plan?
if the answer is no, you can't gift him with data.
if yes, you should reach out to Fizz by chat to fix the issue.
Send them a messenger.They are usually quick to answer and have solved my problems in the past.
Hi Allan, you should contact customer service. Go to the "Solution Hub" (https://fizz.ca/en/solutions), pick a category, then pick an FAQ question related to your problem, and if you are there within the business hours, you should see a green bubble chat on the bottom right of the page and you can tell a customer support representative about your problem!
