I am not able to apply my upgrades.it say plan not active but it is.what can I do?
I am not able to use my upgrades and perks. It shows that your plan is not active but it is activated
  • oiler
    oiler Posts: 9 ✭✭
    I had trouble applying upgrades because isn't allowed while you have an authorized user. I had to remove that one, apply the upgrade and add the user again.
