Data does not work,never.(Manually APN done)
I have used fizz for a few months and i add data into my plan, however, the data that I bought has not worked ever. I am using iphone 6 plus and Android at the same time, but none of them can use fizz's data. I have manually set the APN as you said, still not useful. Hope any of your tech support can fix this for me ASAP, please! Thank you.
Yuan
Yuan
Yuan
Level
Mike
Mike
Mike
Level
5000 / 5000
Here we are users.
After have configured the APN you must select them as default and reboot the phone.
if this does not help, contact the support again.
CHAT
  • Go to this page https://fizz.ca/en/faq/what-are-fizz-network-settings-apn, if you are not connect login
FACEBOOK
CONTACT FORM
Did you find this useful ?
No (0)
Yes (0)
Fizzy
Fizzy
Fizzy
Level
5000 / 5000
With iPhone, you should have the latest iOS installed.
With some Android phones, you need to remove the old APN or perform a factory reset.
If you have confirmed that you have data (via Fizz account > your mobile plan), then you'll need to get Fizz support to look into this. If it cannot be resolved quickly, Fizz support will escalate your issue by creating a ticket.
Mike
Mike
Mike
Level
5000 / 5000
Are your phone compatible? They are for the north america market?
There are different version of iphone for different market and for the android it is the same
You may want to try this ... For the iPhone especially, try to restart the phone. If it asks you to accept network settings when it restarts, answer yes.
Yuan, there's nothing wrong with your phones.
Something went wrong after you changed your plan.
With Fizz, most of the time what was working well will fail after a plan change.
That's at least my experience. You need to chat directly with Fizz customer service to get help.
Bill
Bill
Bill
Level
2
761 / 2000
I guess you need upgrade iPhone iOS to latest 13.x and that's it.
Olivier
Olivier
Olivier
Level
5000 / 5000
again mike is right :)
