Do Fizz allow temporary pause to payments for vacation purposes?
If so, how?
If not, what is the best solution?
Thanks in advance
No they dont. The only way to keep your service is to reduce your plan at the minimum, no call, no text and no data. It's $10 a month taxes not included
Click on the link to see this low cost plan by yourself
https://fizz.ca/en/mobile-plan?CVRG=107&DATA=231&...
There's no pausing.
You can reduce your plan to the minimum one which costs about $10 (Quebec coverage with no minutes, no text, no data).
Upon your return, you will have to select from the plans and pricing available at that time.
Choosing a cheaper plan is the best alternative while you are not using your service. The only drawback is that you’ll have to choose from the plans available upon your return. This might be more expensive than what you currently pay if you benefit from stabilisation-era pricing.
If you have a pre-Oct 17 plan, you will lose the benefits of price discount when you return, and revert back to the new prices.
give your sim card to a friend I guess... if you feel generous or you can charge your friend
