Where are the wifi client isolation settings in the router?
It's also called AP isolation. It's used to isolate Wi-Fi clients from each other or sometimes from wired users.
My two Wi-Fi devices can't ping each other but I can ping them both from wired devices.
The router is behaving like it does client isolation but I can't find the option in the router.
What's going on?
  • OoumFiss
    OoumFiss Posts: 38 ✭✭
    Hi Frédéric,
    Do you get some type of message  AP isolation must be disabled ? is it Chromecast type related ?
    To answer your question, there is no options for such settings in the Hitron !
    The solution for you is to use a third-party router and put the Hitron into bridge mode.
    https://fizz.ca/en/faq/how-can-i-use-my-own-wi-fi-router-fizz
    Another trick would be to set up a second network with a second routeur plugged into an Ethernet port of the Hitron without putting it into Bridge mode.
    Hitron (IP range 192.168.xxx.xxx) -------> 2ndRouter (IP range 192.168.xYx.xxx)
    Run the IOTs through the 2nd router.
    The trouble with that particular setting is that you might have other issues , such as Double NAT but it can be done!
