my sim card is to small what do i do?
You are suppose to have all the adapter for the 3 sizes, nano, micro and standard
If you lost it you can go to any mobile company in a mall and ask for an adapter
Usually you get every size. I you took off a big piece, put the small one into it and put it on the phone. It wil work.
If you mistakenly threw the adapter out and you need a new one ASAP you can buy a cheap SIM card at dollarama
You have many options, each with different costs.
- Get a free adapter from any mobile shop or friend/family.
- Buy an adapter for $1 or more.
- Buy another SIM card.
- Change your phone.
