Hello, there was a lack of money on my account, so the money was not debited yesterday, but I have added money to my account, could you please make a transaction at so my internet can be reactivated? Thank you
From this page https://fizz.ca/en/faq/how-do-i-fix-payment-issue
Only one last attempt will be made between 10 p.m. and 11:59 p.m. on the day preceding your plan’s anniversary date to collect the amount due.
If your payment fails once again, your plan will be deactivated, and you will be notified. You will be informed of the two steps to complete (in this order) to reactivate your service, those being:
Check your payment method: Is your payment method up to date? If you need to add a new one, make sure to set it as the default payment method for your plan.
Make a payment now: Once your default payment method is all set and up-to-date for this plan, look for the Make my monthly payment button in your account. This will trigger a payment attempt, and your service will be reactivated once the payment is confirmed.
Once your payment has been received and confirmed by Fizz (please allow a delay of up to two hours), your plan will be reactivated.
I don't have any other credit cards so I can't add any to make modifications.
You need to have a card regsistered on your account.
If you need a card for emergency use, Canada Post offers them here
you should have a make payment option or update card. try deleting the card and re-adding the card and make payment
Please close this
This solved ?
