I currently have a WF721 home phone hub for my parents. Assuming it is unlocked, would I be able to use it with a valid Fizz sim card (assuming the plan has talk time included)?
Anyone had any luck with this?
The SIM yes, check you HUB if it has the right frequency
If you need a referral code this is mine K61CD, with this code you will receive 25$ to be applied to your 3rd payment.
It is important to add the referral code must be used during the creation of your plan when the taxes are shown
If this https://www.att.com/devicehowto/tutorial.html#!/stepbyste... is what you have then very likely it's compatible with Fizz ( 1900 MHz )
If you bought it from a Canadian shop (bureau en gros) or Candian website (like amazon), then it is likely unlocked and has the required frequencies. So it will work.
If you bought it from a Canadian provider (like telus, rogers), then it is likely locked and will not work with other SIM card.
It should work, but the best way to find out is by taking advantage of the 15 day trial period and trying it out yourself!
