anyone having problems ordering new sim card?
scriabin
scriabin Posts: 2 ✭✭
trying to order new sim card. When entering my address ( which appears in the roll down menu), system shows THERE HAS BEEN AN ERROR, PLEASE TRY AGAIN LATER. What to do? I've been trying for the last hour.
    Mike Posts: 20,643 ✭✭
    Try to change your browser.
    Are you in the subscription area?
    If you need a referral code this is mine K61CD, with this code you will receive 25$ to be applied to your 3rd payment.
    It is important to add the referral code must be used during the creation of your plan when the taxes are shown
    If you still have problem
    CHAT
    • Go to any help page, if you are not connect login
    FACEBOOK
    CONTACT FORM
  • Alfio
    Alfio Posts: 398 ✭✭
    I had a problem as well. Try another browser, and allow the system a few minutes, then check you account again to see if the order went through. First time, I thought it had not gone through, and unfortunately ended up with two SIMS. Gave one to a friend.
    If you need a discount code, please use mine: IDOUU     This will give you a $25 discount on your 3rd month's bill.
