what are kudos and how many points do you get? and when does it get updated
Kudos are likes in FB, you can give 20 per days, each kudo given is 1pts each kudos received is 5 pts
You can receive unlimited kudos, the update is almost instantaneous.11 -
kudo is the equvalent of like, it gives you 1 point per given kudo and it's updated immediately.
There is a limit number of kudos that you can give per day. When you go over that number you'll gain no point.10 -
They are the little hearts underneath the comments. You get them instantly, 1 point for giving one, 5 points for receiving one.12
Kudos are the little hearts underneath the comments (like facebook like). You get the points instantly, 1 point for giving one, 5 points for receiving one.9
