Can I add another 1GB travel add-on before my current one is finished ?
Bruno M. #2164
Posts: 13 ✭✭
in My Mobile
I have seen a lot of comments that you can add another travel add-on when you have used up your first one.
Can you buy the add-on before the first one is used up or by multiples at the outset if you know you need more than 1GB ? (i.e. once you run out of data, you are not online to buy the next add-on)
11
yes you can buy multiple addon in different time4
yes you can2
You can do that, but keep in mind that an add-on expires at the end of your next billing cycle. It means that if you buy it 10 days before the end of your current cycle, the add-on will expire 40 days later. So if you're not sure that you'll use both of them before the expiration date, you better split the purchases.4
Of course you can.
You can buy whatever you want to add on.
Good luck!3 -
All answers are good here.
When your question has been answered, please close your post by clicking on the button "Make best answer".
3 -
Yes Fizzy,
Unfortunately the ‘Make Best Answer” button is not appearing with either Safari or Firefox on iPadOS, so I cannot click the button.
Thanks to all for your answers.2 -
Ag, finally the button appears after posting a reply.1
