Why is my CODA 4680 have no WAN Setup subcategory under basic settings ?
I believe that the wan is used for the authentication and the configuration is disabled by the auto provisioning4
What are you looking for exactly?
With the Fizz modem, you have these menu options:
1. Basic settings > LAN Setup
2. Wireless (2.4G and 5G)
4 -
You don't need to set up the WAN. With DSL you do because you have a username/password but this is not the case with cable internet. Just connect the coaxial and you are online.3
