Use of Mobile Wifi?
I have moved my sim into a mobile wifi device but it says it is Roaming on Rogers and only gives me 2G putting back in my iphone shows Fizz network and full LTE any ideas?
Jay
Jay
Jay
Level
Does this mobile wifi device have the necessary bands to make use of Fizz data? If it's connecting on 2G, that may be because it does not have the needed bands for data on 3G or 4G.
Did you find this useful ?
No (0)
Yes (0)
Mike
Mike
Mike
Level
5000 / 5000
The concept of roaming does not exist with Fizz, in the meantime check if the network is set in automatic.
Sergio
Sergio
Sergio
Level
3
3664 / 5000
Probably because your wifi device is not compatible with Fizz.
You should share a connection from your iphone for your other device that are not compatible.
Takion
Takion
Takion
Level
3
4526 / 5000
Could be that the device is locked to rogers and need to be unlocked
Check the specs of your mobile wifi device. Most probably does not support the frequencies for LTE on Fizz and that is why you are connecting to a roaming partner.
Fizzy
Fizzy
Fizzy
Level
5000 / 5000
What is the make and model of this mobile wifi device?
By the looks of it, it is incompatible with Fizz network. It sounds to be an older device or one not originally for North American use.
Rogers is a roaming partner of Fizz and they are the only provider still offering 2G service in Canada.
In order to help the Fizz community evolve with your question, do not forget to identify the best answer given to you by members of this discussion group using the Make Best Answer button.
Nathaniel
Nathaniel
Nathaniel
Level
1
216 / 750
Maybe your device is block in Rogers.
Barjout
Barjout
Barjout
Level
Is your device locked to Rogers? What is the make and model of this mobile wifi device?
