I have looked through the forums and tried the solutions (like using a different APN) but i'm still getting very slow connections. Its been a few weeks; what should I do?
PS I am located in Montreal. I have the Pocophone
Do you have the right model
Since if you have this
https://www.poco.net/global/specs_m/
Is not compatible with the LTE, it does not have the B4
What do you mean right model? its the f1; and sure, but I rarely even get 3G!
Have you looked at this page? https://www.kimovil.com/fr/ou-acheter-xiaomi-pocophone-f1
Scroll down until you get the frequencies of canadian wireless providers. Look at Vidéotron who's the owner of Fizz.
You'll see that the only frequency your Xiaomi Pocophone F1 will work with is the Band 7 (2600) and that's a secondary frequency. The main frequency used by Fizz is the Band 4 (1700/2100).
So shouldn't I get 4g sometimes? Also thank you for that website, it is amazing!
I'm pretty sure you won't get 4G/LTE very often with this smartphone on Fizz network and even with partners networks in Canada.
I had 4g when i was on Koodo
Koodo and Fizz do not use the same 4G frequencies.
When your question has been answered, please close your post by clicking on the button "Make best answer".
Xiaomi may have different frequency or displays. You can go to their support website to check the frequency capability.
In order to help the Fizz community evolve with your question, do not forget to identify the best answer given to you by members of this discussion group using the Make Best Answer button.
Pocophone dosnt has band 4. I think will be 3G or H+ only.
