How do you place calls using the *Star* key?
Previously (Bell and Telus) you could call a company by pressing the star key and then a number - example:*3222 and it would connect you with CBC Montreal traffic department or *4141 for emergency towing on the Montreal area expressways. With Fizz, it doesn't work or at least not for me! Any suggestions?
18
we are under the stabilization period and these numbers are not completely functional13
So, after the stabilization period the *Star* key will be functional?13
These special numbers don't seem to be a priority for Fizz.
If more people ask for it, then Fizz might make it a priority.
Fyi Videotron mobile supports these numbers
https://support.videotron.com/business/mobile/rates/useful-entertainment-numbers
Telus supports these numbers
I have not seen a similar list for Fizz. It definitely sounds like a good idea.
13 -
It is very useful shortcuts and would be interesting to have.8
In order to help the Fizz community evolve with your question, do not forget to identify the best answer given to you by members of this discussion group using the Make Best Answer button.
7
