Why do my incoming calls go direct to voicemail?
Shirley M. #10663
Posts: 2 ✭✭
in My Mobile
New account & new number. No problem to make outgoing calls, can send & receive texts. Unlimited talk & text plan. Checked my phone settings, not forwarded. Not on airplane mode. Fizz showing as network. What else can I do?
18
If you transfer the number can take up to 24 hrs to complete it.
Did you try to reboot the phone?
This is a full guide to try to solve your problem.
https://fizz.ca/en/faq/i-cant-receive-any-calls-on-my-phone6 -
You may be able to fix the problem by putting your phone on airplane mode for 30s then turning it off. That seems to have worked for a few people experiencing strange behavior with their plans.7
Tried your suggestions, took out the SIM card (again), rebooted the tel., it's not a transferred number. Tried airplane mode off/on. The directions about setting up the APN manually: defaults to Videotron, I can't modify any settings. Nothing, I guess I may have to go to Chat!6
Have you also tried the SIM card on another phone?
If problem persists after troubleshooting, you can contact Fizz support for help.
The idea of this page https://fizz.ca/en/contact-us is to explain how you can access the chat bubble. If you do a search in the Solution Hub related to your issue and access the help page the chat bubble will appear at the right corner.
- You're logged into your Fizz account.
- You're active on a help page such as https://fizz.ca/en/contact-us
- Simply click on the chat bubble that appears at the bottom on the right.
- You're within the business hours: every day from 8 a.m. to 9 p.m. (EST).
- You have disabled any ad blockers in your browser.
7
