I've paid for an Add-on to add data 500mb but there is no data (not travel data)?
I've paid for an add-on but not receiving data I bought for
    Mike Posts: 20,731 ✭✭
    Did you configure the apn?
    If you have problem seeing on the web try to reset the cache or change the browser
  • Vincent G. 7731
    It’s not a APN , I’ve paid but no data been added
    Fizzy Posts: 10,904 ✭✭
    If you paid for the Add-on and it appears on your account, then it should work.
    Otherwise contact Fizz support for help.
    When your question has been answered, please close your post by clicking on the button "Make best answer".
  • Gates
    Gates Posts: 835 ✭✭
    In order to help the Fizz community evolve with your question, do not forget to identify the best answer given to you by members of this discussion group using the Make Best Answer button under the answer you deem to be the best.
