Can I receive calls in Israel?
Can I receive text massages in Israel?
With Fizz, there is no calling in Israel.
You will be able to receive texts and those are always free.
To send texts, it's pay-as-you-go rate of $0.10 per text.
For data, there are 2 travel add-ons available or opt for pay-as-ou-go rate of $0.20/MB
There are no travel add-ons for calling outside of the USA. Only Data add-ons are available. You can go down the pay as you go route for sending text messages. You can receive text messages without having any money in your wallet.
By a Sim card SIM at the airport in Israel if you want to make call.
A suggestion
https://prepaid-data-sim-card.fandom.com/wiki/Israel
And check Amazon
https://www.amazon.ca/s?k=Isra%C3%ABl+Canada+Sim+card&...
