New feature: Universal call blocking
New feature will be implemented Nov 2019 by all Canadian telecoms including Fizz.
https://fizz.ca/en/faq/universal-call-blocking
Will this be good for us?
19
Therefore, only fake number. But is good to know.3
better than nothing. I hope that at least it will block some obvious spam calls, but let's hope it will not block calls from Montreal's hospital appointment system calls as these hospital calls to give you an appointment always show as unknown number.2
Should not block private number but only the caller id which do not respect the standard, for what i understood2
1
