Hi, my card said it was delivered on the 19 of August. All I got was a damaged piece of paper with no card. I would like to have a replacement sent.
You have to order another SIM card here: https://zone.fizz.ca/dce/customer-ui-prod/#/simcard/order
Once you you activated, you'll have to contact Fizz support to request a refund for your first SIM card.
The idea of this page https://fizz.ca/en/contact-us is to explain how you can access the chat bubble. If you do a search in the Solution Hub related to your issue and access the help page the chat bubble will appear at the right corner.
Contact the support Usually they will ask to buy a new one and ask for a refund.
If you need a referral code this is mine K61CD, to be used at the creation of your plan
Why can't you just send a new card rather than adding extra steps?
Can you please just send me a refund for the card that did not arrive?
I am a user as you, you need to contact the support
Ici le lien vers les informations sur le support https://fizz.ca/fr/nous-contacter
Si la bulle n'apparaît toujours pas, c'est que le nombre de sessions en attente est supérieur à notre capacité de traitement. À ce moment-là, laissez-nous un message sur Facebook Messenger ou en privé sur Twitter.
Vous pouvez aussi envoyer un message par l'entremise de Facebook, https://facebook.com/fizzca et cliquez sur envoyer message
Vous pouvez aussi remplir le formulaire de contact, dans votre panel → Mon Profil → Formulaires de contact
How? Everything is DIY. Please send me a link.
not sure if you had this solved or not, but I'd contact fizz on their facebook page.
Please close this
Is this solved ?
