New speed rate maybe ?
Mehdi B. 4237
Mehdi B. 4237 Posts: 412 ✭✭
Hi Fizz,
Do you think to have more like 120 Mbits speed soon ? Like 200 or 400 ?
Regards,
  • Gswim
    Gswim Posts: 543 ✭✭
    that would be great to have different speed options at different prices.
    I don't need that much speed so i would pay less :)
  • Leifuer
    Leifuer Posts: 498 ✭✭
    120 Mbits is already available, check here:
    https://fizz.ca/en/internet?DATA_CAPACITY=10250&DOWNLOAD_SPEED=10252&PLAN=1000
    Maybe in the future there will be 200 or 400, much MORE....expensive!
  • Gswim
    Gswim Posts: 543 ✭✭
    yes, 65$/ month for 120 mbits
    check it out at the link given earlier
  • Gates
    Gates Posts: 835 ✭✭
    In order to help the Fizz community evolve with your question, do not forget to identify the best answer given to you by members of this discussion group using the Make Best Answer button under the answer you deem to be the best.
