Home connection not working
Stephan B. #9852
Stephan B. #9852 Posts: 10 ✭✭
I have no connection I check my modem my cable
    Mike Posts: 20,731 ✭✭
    If you already checked the modem and the cable, you need to contact the support
    CHAT
    Go to this page https://fizz.ca/en/faq/resolving-issues, if you are not connect login
    The business hours: every day from 8 a.m. to 9 p.m. (EST).
    Wait 5 seconds for the bubble icon to appear at the bottom right of the browser and click on the icon to chat with support. Try a different browser if you have issues getting the bubble to appear.
    FACEBOOK
    Your can also send a message via facebook messanger https://facebook.com/fizzca and click send a message (this is a bit slower)
    CONTACT FORM
  • Micah
    Micah Posts: 104 ✭✭
    Try following the instructions here: https://fizz.ca/en/faq/my-modem-connected-cable-my-connection-keeps-cutting-out-how-do-i-fix
    If not you can definitely contact FIZZ support
    Whizz Posts: 19,116 admin
    @Mike you might want to ask for a few more details before sending them off to chat - it might be something the community can help out with - who knows?
    @Micah - thank you for sharing the links to our FAQ's.
    @Stephan - can you give us more details to the issue you're experiencing? Is your account up to date and showing your plan is active? If so have you tried to reboot your modem?
    Thanks,
    Jay
