I enter what I think is the right pin but every time it say I'm wrong. How do I change my voicemail pin without having accès to my voicemail account?
Modifiy your access code (PIN) to access your voicemail online, directly from your Fizz account.
(Under: My plans > Manage my plan > Advanced parameters > PIN to access my voicemail)
IMPORTANT: Unsafe sequences will be refused (for example : 1234, 8888, etc.).
You may consult these Fizz FAQs if you have further quesitons about your voicemail
https://fizz.ca/en/faq/how-do-i-set-up-my-voice-mail
You need to go in your panel
My Plans > Manage My Plan > Advanced Settings > PIN to Access Your Voicemail
If it doesn't work you might have to contact the support :
To contact Fizz, click on the link below and make sure you're logged into your Fizz account. The bubble chat will appear at the bottom right corner.
Business hours: every day from 8 a.m. to 9 p.m. (EST)
