I get disconnected when using cell. recieving or calling. ?
We are 3 that have the same issue. It doesn't matter where we are situated locally. We also did the 3 stupid steps. power off, airplane, sim card removal.
It's been like this on and off for a month now. My wife got fed up and switch services since we needed a functional cell at home. We are about to do the same.
    Mike Posts: 20,747 ✭✭
    Did you try to report your problem to the customer service? Did you check the signal? Which phone are you using?
    CHAT
    Go to this page https://fizz.ca/en/faq/resolving-issuesif you are not connect login
    Wait 5 seconds for the bubble icon to appear at the bottom right of the browser and click on the icon to chat with support. Try a different browser if you have issues getting the bubble to appear.
    FACEBOOK
    Your can also send a message via facebook messanger https://facebook.com/fizzca and click send a message (this is a bit slower)
    CONTACT FORM
  • Yelena
    Yelena Posts: 1,861 ✭✭
    This might sound ordinary, but Fizz is still in stabilization period, and possible service disruptions should be considered when you subscribe. If you cannot tolerate this, you should definitely change the provider.
