I forgot my voicemail PIN and therefore I cannot access my voicemail. I've been looking for a solution to reset my password. Apparently I need to go to "My plans" and then "Manage my plan" followed by some other steps. Unfortunately, when i click on "My plans" all I see is an offer to create a plan, no "Manage my plan". I made sure I was logged in to my account but still no luck. What should I do now to reset my PIN???
Katia.
Log into your internet Fizz account
My plans
Manage plan
Advanced Parameters
PIN to access your voicemail
> Change pin
Have a good day !...
You can contact Fizz by opening a help page. Try this one https://fizz.ca/en/faq/im-unable-log-my-fizz-account-what...
Hello Katia,
Are you sure you are logged on the correct email account?
You should be able to go "OVERVIEW" or "MY PLANS" to see "MANAGE PLAN"
Then click on "ADVANCED PARAMETERS". You will see an option to change PIN to access your voicemail.
Enter new 4 digit PIN and press "SUBMIT".
If you cannot see your Mobile plan or this option on your account, you will need to contact Fizz support for assistance.
You can send a message by facebook https://facebook.com/fizzca
Or you can use Fizz chat. Make sure that:
