Fizz team,
brilliant experience in canada, however while travelling i tried to add roaming add-on, it work perfectly and the speed is OK, however is there a way to see the remaining balance of the same roaming data? as i only can view my plan data remaining in the online,
thanks
Elias
If you click on "My plans", you should see your travel add-ons and their usage. It is not on your Overview tab.
It might be a bug. I bought an add on for Europe for my son and and we never saw the remaining balance. It was like he was not using any data. Data stopped working one day so I guess he used it all and I bought him another 1 Go. That time it worked and we were able to see the consumption.
In the meatime you can verify on your phone data usage.
Code_KRUEW was made best respondent
MT answered
Gallina answered
Code_KRUEW answered
Elias posted a new question
