Hi I picked 0 gb of LTE on my plan would I be charged if I put my LTE on or is there a way to block the LTE cause my daughter is the one using the phone so I would like too known cause other whise I don’t want this plan
No you will not be able to use LTE if it's not in your plan and therefore you won't be charged,
as long as you don't put any money in "Wallet" feature.
Fizz is a prepaid service. You can't be charged.
FYI you have probably received a 250 Mo bonus. You can apply it to your account, that would give you access to LTE 250 Mo/month for 2 years.
Do not worry about that, if your plan has no Data, you will not be able to use LTE unless you put some money in your Wallet (my plan--manage plan--Wallet).
However, since you activate your plan, you have an upgrade of 250 Mb to add (free charge), enjoy that for two years!
No worry, her data is blocked if the free 250m run out . You can buy a 500m add on for her . Again , data stops after she used all. I like fizz very much because it is over usage worry free.
