How hard/easy is the manual installation?
It's very easy. If you have already setup a router then you should be able to do this.3
It's easy. You just have to plug it and follow the instructions. They are inside the modem's box.4
Btw if you need a code to get your 25$ bonus here is mine: A4CEX
Or here is a link where members can share their codes:
https://communaute.fizz.ca/questions/2020153-code-reference-prime-bienvenue4
