Issues Sending SMS or receiving
Jordan B. #8340
Posts: 1 ✭✭
in My Mobile
Anyone in Ottawa still unable to send SMS. Mine keep going through as Sent to
email and the receiver isn’t getting them
At all?
At all?
12
Have you reset your phone.
Everything should be ok now.
Just shut down and open your phone2 -
Take easy, as we are Fizzers and we are in period...2
His problem started before the implementation period, I don't think that it's related to that. Something else most likely.
It was always working fine until yesterday ? I just want to see if it could be APN related.
Things might be improving over the implementation, hopefully.1 -
You will need to contact support. It sounds like this is only affecting you.2
