Is this Motorola compatible with the fizz LTE network ?
Most of the phones made these past 5 years in north america are compatible.
For fizz calls you need HSPA 850 MHz or 1900 MHz. You have boths.
For data you need the bifrequency 1700/2100 MHz. Which you have. I looked at your phone specs, you have a big range of GSM/LTE/HSPA technnology. You are fine.
If you liked this answer, don't hesitate to put it as <Best answer>
Yes it seems compatible it has LTE Band IV
You can also use this site, you need to have the precise model
https://www.frequencycheck.com/models?utf8=%E2%9C%93&...
You can check by yourself on the FAQ: https://fizz.ca/en/faq/compatible-devices
Fizz uses for an LTE-compatible phone configured with LTE network preferences:
- Calls: Your device must support HSPA 850 MHz or 1900 MHz frequencies
- Mobile data: Your device must have dual-frequency support for 1700/2100 MHz (also called AWS or band IV)
Your phone seems to use the LTE band 4 so everything's all right.
