I have USA +Canada Coverage. I am in the USA right now and it connects to At&t and not Fizz EXT. If I turn on roaming data for data or use the phone for calls and texts, will I get charged extra? Thanks!
Malay
You have Canada+USA therefore, you can use your phone as home.
Calls in USA and Canada if you have unlimited, they will be unlimited!!
If you have unlimited texts same idea.
The data is the same pool.
I have the same plan
You will never get charged extra by Fizz since it is a prepaid service. You get what you've paid for. So if your phone works, there is nothing to worry about.
Not completely true, if you have the money in your wallet you can be charged. :( But not in your case.
@Mike: right, thanks for the update! Anyways I assume that with Canada-US coverage a person who goes to US probably wouldn't put funds in the wallet...
