I have the Canada and USA plan. I'm presently in the USA and I cannot use Data or receive texts. The roaming function is on (iPhone 6s). Is this a common problem with Fizz?
Are your APN settings configured correctly?
https://fizz.ca/en/faq/what-are-fizz-network-settings-apn#1
Also check your provider selection setting -
iPhone: Settings → Operators → Automatic/Fizz
For now we have a problem sending SMS in Canada. :( Other users reported slow data when outside the coverage zone this week.
If you're outside the country for vacation, have you considered getting a SIM card in USA ?
I would get a US SIM card; much cheaper.
@Soula: is your issue resolved? Can you close the topic by choosing the best answer?
