Hi Qiuguo
Are you calling the voicemail from your Fizz phone?
If you forgot the PIN, you can reset it from your Fizz account: (Under: My Plans > Manage My Plan >...
I haven't use my sim card yet and it is still blocked. But, when I enter the number to activate it, I get an error saying that the number is already assigned to an other member...
Hi Raphael
Did you receive this message on your first activation attempt?
If yes, you should contact Fizz support: https://fizz.ca/en/contact-us
However if you already...
Hi Karen
First of all, Welcome to Fizz!
If you are able to make outgoing calls and send out texts, then your Fizz line has been successfully activated.
The pending...
Hi Jacques
This means your request has failed. You must contact Fizz support.
When contacting Fizz, make sure
1. Your account with...
My number didn’t transferd and i already payed for it my sim is not active and i can’t have another num too ,help me for transfering my numb or refound my money?
Hi Nilab
I will start saying that you have 15 days trial period
Regarding the transfer problem
it can be one of the following
1. The number you entered was not...
