What are the best wifi settings?
Mike F. #6098
Mike F. #6098 Posts: 15 ✭✭
I just got home internet installed but it is running very slowly. I should be getting 30 MB but I'm getting around 7 MB right now with wifi . When it's connected by wire to the modem I am getting the full 30mb. Can someone share their Wi-Fi settings like bandwidth, Channel, etc.
The modem is in the next room so don't get why the signal is so poor.
  • Gallina
    Gallina Posts: 755 ✭✭
    Which app do you use to measure the speed?
  • Mike F. #6098
    I'm using speed test.net
  • Dominic L. #1933
    Dominic L. #1933 Posts: 726 ✭✭
    Nice summary Julien.
  • J D. #792
    J D. #792 Posts: 316 ✭✭
    Like @Julien said install and use the app Wifi Analyzer to help you find the best channel for your wifi setting. https://play.google.com/store/apps/details?id=com.farproc.wifi.analyzer&hl=en_CA
    But the wifi from the Fizz's modem is not that great in speed. If you want a consistent fast speed wifi, as fast as wired, maybe consider getting a Wifi Mesh Network system. Personally I'm using it and the wifi speed is great, as fast as wire connected. Here's some info, if interested.
    https://www.pcmag.com/roundup/350795/the-best-wi-fi-mesh-network-systems
    I'm using the TP-Link Deco M5 Wifi system, signal is strong and speed is consistent everywhere in the house, from basement to 2nd floor.
