My phone works, but why data doesn't work?
did you make sure that data is active on your phone check the this in the setting of your phone6
5
Check your apn settings. If they are incorrect you will not have mms or internet working5
Most likely there is something with your APN.
Look at the video, and follow it step by step. Then everything should be fine.
https://fizz.ca/en/faq/what-are-fizz-network-settings-apn4 -
yes, the 1st thing to do is to verify the APN setting as mention here above4
