can i schedule my FIZZ modem to shut down between specific houres? (somehow like smart devices)
Marouane A. #2913
Posts: 6 ✭✭
in Internet
I want to have for example :
at 8am shut down the modem, because i am out of home
at 6pm : turn it on, because usually i go back at this hour.
You can schedule the wifi5
You can use a timer to do this. Just plug the modem in the timer.4
Scheduling the wifi just blocks it for devices, without turning it off.
I dont want to buy a timer just for the mode. The previous one was able to being scheduled. It means this one can't?...5 -
I don't think that they are offering a modem with many features.2
There isn’t a function on the provided modem/router to do so.2
