How do travel add-ons in europe work?
Iman_Ahmad
Posts: 1 ✭✭
in My Mobile
I'm planning to travel to europe for a month and I want to know how the travel add ons work. After I put money in my "wallet", how does it charge? Once I enter the country? And how much should I put in my wallet?
13
You have two options: buy a data travel add-on (pay per block of data) or pay as you go (add funds to the wallet). Go to My plans => Manage => Travel and type in the country you'll be visiting.
Also check the option of buying a sim card at your destination. It might be cheaper.7 -
Just like Yelena said, you can buy a travel add on or pay as you go5
@Iman_Ahmad: can you close this topic by choosing the best answer?3
I recommend to buy a one time travel sim card. It's a lot cheaper. You can find these sim card at amazon.ca there are a lot of them. Just search for "europe travel sim card".3
You can check the rates in the adds-on or travel section of manage plan.
It will charge when you are using European Networks3
