Voicemail PIN does not work
Yes is there
(Under: My Plans > Manage My Plan > Advanced Settings > PIN to access your voicemail)
if you do not have it, probably you do not have the voicemail in your plan4 -
Try to contact fizz by chat or Facebook messenger to check!4
