It's been 4 days since my mobile Internet is interrupted. And i have miss several job opportunity . What should i do?
Have you tried any troubleshooting?
- Logon your account to check plan status and make sure you still have data.
- Make sure the data settings on your phone are good. Recheck the APN settings.
- Try rebooting phone, enable/disable airplane mode.
- You can also try your SIM card on another phone.
If problem persists, you need to contact Fizz support.
You can send a message by facebook
https://facebook.com/fizzca
Or you can use Fizz chat. Make sure that:
did you make sure you data is not turned off on your mobile sometimes its a simple as turning back that data on
No similar question
