Home Internet down due to network upgrade and no advance notice?
Susan W. #2572
Susan W. #2572 Posts: 3 ✭✭
Home internet has been down for 4 hours and no one can confirm when it will come back. Worst thing is there is no notice in advance. Fizz simply decide when they want to cut the service any time, screw you the customers. Support is great too. Take them almost 2 hours to find out there's an upgrade in the area. Wasted my time on troubleshooting everything. And best of all is to ask me to factory reset the modem and dare to tell me there's no backup feature, which I know there's one. Either that support is not competent or just lie on my face. In the end, support just tell me good luck and hope the service will come back soon. At this moment, there's still no service after 5 hours!!! Fizz, tell me why should I stay?!?!
    Fizzy Posts: 10,901 ✭✭
    I hope your internet is working now.
    If still problematic, please try these:
    - Check your Fizz account to make sure the plan is still active and payments are up-to-date.
    - Factory reset the modem and try reconnecting again.
    Follow these troubleshooting tips: https://fizz.ca/en/faq/i-connected-my-device-using-network-cable-i-still-have-no-connection-internet-how-do-i-fix-it
    If the modem lights do not respond, you may have a defective modem.
    Contact Fizz support during business hours with this link: https://fizz.ca/en/faq/resolving-issues
