Hey Everyone!
About 3 months ago I switched to an Iphone 8, however since I switched I have been stuck on the 3G network and I have tried a bunch of different things to fix it but unfortunately nothing has worked. Does anyone have any suggestions how I could fix this?
Facebook messenger support is extremely helpful. I've gotten my problem fixed quickly over there, try that first :)
08:00 to 21:00 week time and
10:00 to 18:00 weekend
CHAT
Go on this page https://fizz.ca/en/contact-us, if you are not connect login then
A bubble icon will appear at the bottom right of the browser and click on the icon
FACEBOOK
You can also send a message by facebook
https://facebook.com/fizzca and click send a message (this is a bit slow)
It's a common problem. Try messaging facebook page or going on the help page and messaging in the live chat
Contact Fizz support to get this sorted out. Facebook is the best way to contact them.
had a similar problem, to fix the problem as it was mentioned contact fizz directly
I suggest you contact Fizz customer service via Facebook messenger and then select a best answer to close this question.
